fabtech lift not true 6 inches
Old Mar 29, 2007 | 07:57 PM
buffgator's Avatar
buffgator
Default fabtech lift not true 6 inches
My freind and I both have 03 1500 qc 4x4. We both got our trucks lifted at the same time, I whent with the 6in fabtech, he whent with the 6in skyjacker. He runs 33s and I run 35s. The thing that pisses me of is his truck sits right level with mine only running 33s. I do some research and find out that the fabtech lift is truly more like 4.5in of lift, while his skyjacker is a true 6in of lift. Im way mad, I paid way to much money for what I thought was 6in, not 4.5. I mean give me a break it only took 3in blocks to level me out. They had to put like 5in blocks on his to level him out. Both trucks where done at the same shop, I was worried at first that they made a mistake and got me a 4.5in lift, but nope they showed me the order it was 6in. Any way this happened like 2 years ago, I finaly decided to vent it out though.
Old Mar 29, 2007 | 08:03 PM
hemiyellow's Avatar
hemiyellow
DC Insider
Default RE: fabtech lift not true 6 inches
man if that was me then i would been callin fabtech up and tellin them you want your money back or somethin...i wouldnt have put up with that crap for 2 years
Old Mar 29, 2007 | 08:30 PM
sharpshooter's Avatar
sharpshooter
to bad its 2 yrs later
Old Mar 29, 2007 | 08:41 PM
buffgator's Avatar
buffgator
Yeah, I dont know if there is just a variation in height, or if all there 6in kits sit lower than 6. I have seen other posts on forums other than this where people have complained about not getting a full 6in. Who knows? Maybe fabtech ment its six if its lifted and than torqued up.
Old Mar 29, 2007 | 10:27 PM
dirtydodge02's Avatar
dirtydodge02
You could always crank up the torsions and get taller blocks for the rear...
Old Mar 30, 2007 | 12:27 PM
Tailbuster's Avatar
Tailbuster
it depends on the manufacturer, my Pro Comp Lift was supposed to be a 6 inch lift, but after I did some checking it was 6 inches in the front and 4.5 in the rear. Now I know that it is done this way to compensate for the truck being somewhat unlevel, but they need to advertise this information better. Which is obviously what happened in your case, I would complain to the manufacturer anyways.
Old Mar 30, 2007 | 12:41 PM
Yellowsally's Avatar
Yellowsally
I am no expert, but I have installed lift kits to 4 or 5 of my last trucks/Jeeps, none of them came out to be what they claimed. For example maybe the front came up 4" and the back 2.5" and so on. If your goal was to run 35's then you got it. I don't understand why you are upset. Were you just trying to be taller than your buddy? My experience is that the least amount of lift to clear your tires is better when you use itoff road. I'm not trying to make anybody upset, but I just don't understand the complaint.
