02 Ram 5.9 valve problems
Old Mar 30, 2007 | 10:09 PM
iusuallydriveVWs's Avatar
iusuallydriveVWs
Default 02 Ram 5.9 valve problems
I've had a misfire for a few months now on my 2002 Ram 5.9 4x4 with about almost 74k miles that i've been trying to fix, it comes and goes. The fault is always the same, cyl #8 random/multiple misfire. So I pulled my plugs and checked my cap and rotor, and sure enough they all looked worn enough to probably be the originals. So changed them all (with factory parts purchased at my local Dodge farm) and even changed the cyl #8 plug wire, and the fault still persists. So I called the dealer to ask them what they thought, and before I could even finish my story the service guy said that it's probably because of bad valve seats, or something of that nature, it's quite common on 5.9 engines of that era, and they keep lots of new heads stocked in the parts department. Thing is, they said they usually see it around 100k miles or later, I'm just about to turn 74k, and this has been going on for pry about the last 3-4k miles. I bought the truck used in great condition, and I bought an extended warranty so I should be ok, but it's still a major PITA. Plus I think my rack and pinion is leaking too. Anywho, does anyone else have any experience with this problem? Thanks.
Mike
Old Apr 2, 2007 | 11:52 PM
iusuallydriveVWs
Default RE: 02 Ram 5.9 valve problems
bump
