Propane injection
Old Apr 1, 2007 | 12:13 PM
pakaalbite's Avatar
pakaalbite
Default Propane injection
Will it work on the 4.7L V8? Where do i find a kit? How much $ ? Will it save gas?
Old Apr 1, 2007 | 04:44 PM
pakaalbite's Avatar
pakaalbite
Default RE: Propane injection
anyone?
Old Apr 1, 2007 | 07:06 PM
Pirata's Avatar
Pirata
From: 2nd star to the right, then straight on until morning
Patience child, all things come in time.
Old Apr 1, 2007 | 07:15 PM
Johndcjr1989's Avatar
Johndcjr1989
from my understanding it will work on any engine but it requires modifications, and unless you plan on keeping your truck a long time, the gas you save might not justify the cost of doing the conversion. now i have no idea about who makes a kit, where to find it, or if anyone currently produces one for the 4.7. i have heard of a couple of people running propane kits on the hemis though, so it might be easily adaptable to the 4.7. good luck with it.
Old Apr 1, 2007 | 08:39 PM
pakaalbite's Avatar
pakaalbite
thanks. any of you hemi owners have it?
Old Apr 1, 2007 | 09:37 PM
claydawg's Avatar
claydawg
I don't personally, but maybe this will help:
https://dodgeforum.com/m_752162/tm.htm
Old Apr 2, 2007 | 03:39 PM
Yellowsally's Avatar
Yellowsally
I'm sure you can get it for 4.7. The kit I have is www.ecofuel.com. Technocarb is another company that makes kits. Good luck.
Old Apr 2, 2007 | 04:58 PM
pakaalbite's Avatar
pakaalbite
will mileage improve?
will i have a power increase?
should it pay for itself?
Old Apr 2, 2007 | 05:16 PM
Jetpig's Avatar
Jetpig
Propane injection is for diesel engines. It greatly ups the power production.
You can get a propaneCONVERSION for your truck where it will either run on gas or propane but not both.
Pig
Old Apr 2, 2007 | 05:28 PM
Yellowsally
mileage will most likely go down 5-10% Power gains will probably be very small. The key is the price of the fuel and better emissions. I do think that it will pay for itself. The kit installed is probably around 4 to 6 thousand. There are many options for tanks. Buy a used tank that mounts in the back or spend a thousand or two on new tanks that are hidden from view. Just as a side note the system is an injection system. There will be new injecors for the propane and they will sequentially inject just like your fuel rails and injectorsdo now.If you have more questions there is a thread called Hemi on propane that has discussed this conversion.
