Need help with P0403 error
Old Apr 6, 2007 | 12:46 PM
Pingeye's Avatar
Pingeye
Default Need help with P0403 error
P0403 Exhaust Gas Recirculation Circuit Malfunction on a 2004 5.7 resulting in a ping/vibration.
Do EGR valves go bad? I removed mine and cleaned as well as I could with carb cleaner. The valve was in the closed position and nothing seemed to be clogged. Does anyone know how to troubleshoot this error or is there a shotgun approach that has a high probability of working? Also, where is a good place to purchase a replacement valve if needed? My truck has 45k miles and I was hoping it would be covered by an emmisions warranty but was told no due to the lack of CA emmisions.
Old Apr 6, 2007 | 01:03 PM
Foiled's Avatar
Foiled
Default RE: Need help with P0403 error
Read your warranty manual about the emmisions. If it says you are corvered then take that in and force them to repair it. There is a different warranty if you live in CA so if you do look for it.
I would say yes. They can get clogged. It is recirculating exhaust gas and it is not clean. So build up could happen. I am sure you can buy one of these at an auto parts store or from the dealer parts shop.
Old Apr 27, 2007 | 06:37 PM
Pingeye's Avatar
Pingeye
Just wanted toclose out this post...
Mileage in 45202
Vibration due to loose U Joint. Part covered by warranty (5014733AA)
P0403 may have been a false call but replaced EGR valve (53032509AM)
EGR valve is simple to replace and priced at $47.80.
