True Dual Exhaust
Old Apr 16, 2007 | 05:46 AM
BIG NATE's Avatar
BIG NATE
Default True Dual Exhaust
I am considering having magnaflow true duals put on the truck, two mufflers not the dual in / dual out single. I know that the MDS will make a sound that alot of people dont like, i have already come to grips with that. Is it more or less effective /efficient to have true duals verses single in dual out.Will I loose power with the true doals that i would not have on the single. I havebeenreading alot of the post on here for a while and you guys haveput alot of good things out.
Thanks
Old Apr 16, 2007 | 09:47 AM
tailgatedrinkin's Avatar
tailgatedrinkin
Default RE: True Dual Exhaust
make sure you run the right size pipe, because if you run them to big then you will lose low end torqe
