miss fire in more then 3 cylinders?
Old Apr 23, 2007 | 04:16 AM
dowale41's Avatar
dowale41
Junior Member
Default miss fire in more then 3 cylinders?
i hooked my truck up to a scan tool at work and i was miss firing on the 5th and 7th cylinder and a miss fire every once in a while and it said that it has been doinf this for 600 miles...the engine has over heated on me twice due to the water pump i changd the spark plugs...but does anyone think i could of fried the coil pakcs or any suggestion would be greatly appreciated mabybe simmilar problems with the 4.7?
Old Apr 23, 2007 | 04:26 AM
hemiyellow's Avatar
hemiyellow
DC Insider
Default RE: miss fire in more then 3 cylinders?
if it's a multiple cylinder misfire, you need to look at things that affect multiple cylinders, not just one.....such as a ground, clogged fuel rail, computer, etc....
Old Apr 23, 2007 | 04:42 AM
DeWalt378G's Avatar
DeWalt378G
You said you changed plugs. Check your harness clips on the coil packs and make sure they are in and locked down.
BTW I'm in Broomall
Old Apr 24, 2007 | 01:12 AM
dowale41's Avatar
dowale41
Junior Member
everything is clipped down but i think i fried a couple of coils...thank u
