Electric Shift on the fly or stick?
Old May 1, 2007 | 08:12 PM
roadrnnr's Avatar
roadrnnr
Default Electric Shift on the fly or stick?
My 2007 Ram has the electric shift on the fly. I now notice some come with the stick on the floor.
Can some one explain the difference if any.
Do they both operate the same, just one shifts electrically and when in 2H are they both disconnected the same?
thanks,
Old May 1, 2007 | 08:50 PM
M14's Avatar
M14
Default RE: Electric Shift on the fly or stick?
Maybe I don't understand your question, but my 07 PW has the floor shift, which is basically a mechanical linkage. For me, I prefer this as I think it can be more realiable, and this is the type of system I look for.
Old May 1, 2007 | 09:38 PM
hemiyellow's Avatar
hemiyellow
DC Insider
[align=left]this should answer your question....[/align][align=left][/align][align=left]SHIFT MECHANISM (electric switch on dash)[/align][align=left]Operating ranges are selected with a dash[/align][align=left]mounted shift selector switch. The shift selector[/align][align=left]switch provides a input to the Transfer Case Control[/align][align=left]Module (TCCM) to indicate the driver’s desire to[/align][align=left]change operating ranges. The TCCM uses this input,[/align][align=left]along with input from the transfer case mounted[/align][align=left]mode sensor and information from the vehicle’s bus,[/align][align=left]to determine if a shift is permitted. If the TCCM[/align][align=left]decides the shift is permitted, the TCCM controls the[/align][align=left]shift motor, mounted to the exterior of the transfer[/align]case, to perform the shift.
[align=left]SHIFT MECHANISM (floor shifter)[/align][align=left]The transfer case is operated by an adjustable floor[/align][align=left]mounted shift linkage. The transfer case shift lever[/align][align=left]is directly attached to the shift sector. The sector[/align][align=left]operates the range and mode forks within the transfer[/align][align=left]case.[/align][align=left]A straight line shift pattern is used with a NEUTRAL[/align][align=left]detent. Lever range positions are imprinted in[/align]the shift ****.
Old May 2, 2007 | 01:03 AM
HemiLonestar's Avatar
HemiLonestar
One is electronically actuated....one is manual.
