Wiring Harness Plus behind grille?
Old May 6, 2007 | 05:26 PM
spinfreak's Avatar
spinfreak
Default Wiring Harness Plus behind grille?
While screwing around on the truck today, I started looking at stuff a little closer. I noticed that there is a plug that's capped off on a wiring harness right next to the driver's side headlight. I know there's alot of different plugs on the truck for different options/accessories that are/were available. Does anybody know what that plug in particular is for?
FYI....I'm not talking about the plug that's behind the bumper for the fog lights. This one is right there as soon as you open the hood. It's mounted right onto the bracket for the driver's side headlight.
Old May 6, 2007 | 08:38 PM
cr80renob's Avatar
cr80renob
Default RE: Wiring Harness Plus behind grille?
I wondered the same thing so I asked it a while ago and here is what I got.....
ORIGINAL: vwomein
That's your outside temp sensor for the overhead gauge pack. Your fog light wire is by the drivers side
back of the front bumper bar(if yours is prewired).
Here is the thread if you want to see a pic....
P.S.- I edited the page because there was a link in there that didn't work, so I took it out.
Old May 6, 2007 | 08:41 PM
cr80renob's Avatar
cr80renob
P.S- Too bad New Jersey Devils couldn't rally back and win the series! That sucks!!! [sm=smiley19.gif]
Old May 6, 2007 | 09:02 PM
spinfreak's Avatar
spinfreak
That's weird. I even mentioned to my fiancee that for a wire to be all the way up front like that, that I would guess that it could only be for a temp sensor.While I didn't look very closely at it, it did look like all of the other connectors that are just capped off with nothing attached to it. I guess maybe it wasn't just capped off, but the end was actually the temp sensor, because I have the overhead console with the temp and it works.
Old May 7, 2007 | 12:49 AM
FFMedic1479's Avatar
FFMedic1479
If you have an overhead temp/ compass/ trip computer... it is the thermostat for that.
Old May 7, 2007 | 01:05 AM
HemiLonestar's Avatar
HemiLonestar
Sometimes it just makes it in. My wife's Liberty has one wired in, same part # as mine, works the same (I plugged into my harness to test it). Except she doesn't have an overhead console. Yet, anyway, but this will make my task a little easier.
