kNOCKING REAR END
Old May 7, 2007 | 05:54 PM
CANTDODGEITRAMIT's Avatar
CANTDODGEITRAMIT
Default kNOCKING REAR END
Has anyone had the problem where at low low speed cornering their rear end knocks. I'm basicly wondering if its a common occurance on trucks with a tow package on it or is my rear end pooched. Ihave been told that theres a different diff for those trucks.
Old May 7, 2007 | 07:48 PM
Hemichief's Avatar
Hemichief
Default RE: kNOCKING REAR END
Without being a mechanic I think that your limited differential is in need of a fluid change with the additive. Did you have a recent rear diff fluid change? if so, did you add the LSD additive? I would stop driving it, before you smoke it and change the fluids.. that might do it.
Old May 7, 2007 | 11:33 PM
CANTDODGEITRAMIT
I haven't had anything done to it, myself.I've only put 15000KM on it sinceI bought it used. But thanks for the tip I'll have to take it into the dealership I bought it from and see if they might have done anything to it. If theresanything wrongitsstill under warranty.
Old May 8, 2007 | 01:01 AM
Hemichief's Avatar
Hemichief
Anytime... I just had my rear diff serviced and the guy that helped me service it (mechanic) was adamant about the additive.
I hope it helps you...
Old May 8, 2007 | 02:38 AM
djr04's Avatar
djr04
Another idea to toss up could be wheel hop from the lsd kicking in while turning. If you didn't have the lsd additive it would probably cause the hop to be worse.
