2004.5 Suspension problems
Old May 17, 2007 | 01:35 AM
2004.5cummins's Avatar
2004.5cummins
Default 2004.5 Suspension problems
first time poster here so here it goes.
i have a 2004.5 Rail line 600 cummins, 2500 quad cab with 8' bed. just recently my front end has started squeaking really nasty when i take big bumps, so i got under and have determined that it is my spring on the right front tire, i first coated it in litium grease, not effect, then in oil, and finally in WD-40. still sqeaking and starting to get worse. i am a college student and cant afford to take it to the dealer. anybody have any ideas?
Old May 19, 2007 | 02:10 AM
ATsGCSRT8's Avatar
ATsGCSRT8
Default RE: 2004.5 Suspension problems
Check all your bushings up front. A lot of times this is all it is. They get worn and crack, and in turn squeak!
Old May 19, 2007 | 02:39 PM
deanj287's Avatar
deanj287
it sounds like the body mount right behind the front tire. mine does that or did until i pulled the bolt and coated the damn thing with lithium grease. the mounts dry up and its dry rubber against metal.....lovely noise eh?
