Throttle Body spacer
Old Sep 15, 2004 | 05:17 PM
Hemi4Me's Avatar
Hemi4Me
Default Throttle Body spacer
I have a 2004 Dodge Ram Hemi with a Flowmaster 40 Series dual exhaust system and a 77 Series K&N High-Flow CAI System. Will a throttle body spacer help out my mid range power and will my CAI system still fit if I added a throttle body spacer???
Old Sep 15, 2004 | 05:29 PM
Snafu's Avatar
Snafu
Default RE: Throttle Body spacer
Throttle body spacer does absolutely NOTHING for a multi-port injection engine. The point of a spacer is to increase the volume in the intake for the older TBI and carburated engine, giving the air and fuel more time and room to completely mix. The newer multi-port system injects fuel right at the end of the intake runner. The only thing going through your throttle body is air. The extra volume does nothing for you because fuel is added later. If you want to match the exhaust, you need a larger bore throttle body. I believe 52mm is what you want to look for.
Old Sep 15, 2004 | 11:03 PM
mopowrmike's Avatar
mopowrmike
who or where can i find a throttle body for the hemi?
Old Sep 16, 2004 | 06:35 AM
98dodgeramsst's Avatar
98dodgeramsst
Check out the 52mm throttle body post.
Old Sep 16, 2004 | 01:26 PM
Mikeg1005's Avatar
Mikeg1005
Snafu was right, they do nothing, I have heard this and I have seen articles by manufacturers that say that this does nothing to our type of engine.
MIke
Old Sep 16, 2004 | 10:00 PM
Racer Rob's Avatar
Racer Rob
Y eah I put one on, noticed no difference other then an annoying whistle sound. Took it off and threw it in the closet.
Old Sep 17, 2004 | 01:04 PM
94ram4x4 5.9's Avatar
94ram4x4 5.9
If you plan on doing any upgrades to your engine, take a look at Hughes Engines first! You do not want to go by the throttle body size (i.e. 52mm) you want to compare by the airflow rating at 1.5"Hg pressure drop. In other word don't just look at the throttle body plate diameter, look at the cfm rating. It is merely a marketing scheme to get people to buy a spacer they don't even need!
Old Feb 23, 2006 | 03:57 PM
daytonajoe's Avatar
daytonajoe
Purchased this airaid spacer along with KN 77 series cold air intake, the intake is awesome and sounds great when you call on the hemi,as for the spacer..I put that thing on for one day, the "whistle" in my opinion is a gimmick..you hear something and therefore think you are gaining something when really the only thing I gained was what sounded like a vacuum leak other than that nothing gained..actually lost $ 109.00, once you put it on the truck they won't take it back. Next instead of these cheap gimmicks I am going for the Gibson log style headers..should bolt right up to my borla exhaust.
Old Feb 24, 2006 | 01:17 AM
silvernightmare's Avatar
silvernightmare
Send me your money and I will snap my fingers and make your ram 0 to-1 HP and Torque better. Just kidding, do not waste your time and money.
Old Jan 12, 2008 | 12:03 AM
ramfx4's Avatar
ramfx4
hey do any of yall want to sell me your un used throttle body spacer?????? it dont matter to me if i gain any power, i just like the sound of it. i have a 2004 dodge ram with a hemi. So Send me a message at ramfx4@sbcglobal.net
