fog light question
Old May 20, 2007 | 03:07 AM
mikegevas's Avatar
mikegevas
Default fog light question
is there a way to keep my fog lights on when my high beams are on. I live on a ranch and would like he extra light. Also can you have both high and low beams on?
Old May 20, 2007 | 03:20 AM
CarGuyOhio's Avatar
CarGuyOhio
Default RE: fog light question
https://dodgeforum.com/m_197878/tm.htm
Old May 20, 2007 | 04:18 AM
djr04's Avatar
djr04
The electrical system is a little different between 02-05 and 06-07, so keep that in mind if you plan on doing this mod. For a simple trick, although tiring over long distances, after turning on your brights pull and hold the lever back again. The brights will still be on, and so will your fogs. However, as soon as you release the lever, the brights will go back to normal lighting, and the fogs will still be on.
