Check Engine Light?
Old May 20, 2007 | 04:22 PM
xtremewheelz's Avatar
xtremewheelz
Default Check Engine Light?
My 2003 Hemi Ram has a check engine light on. The code says a minor vacuum leak. The gas cap is on tight, so I don't know what else it could be? The truck only has 43,000 on it. Any help would be greatly appreciated. Thanks.
Old May 20, 2007 | 04:48 PM
cyclone429's Avatar
cyclone429
Default RE: Check Engine Light?
check all conections in the air cleaner, possibly PCV, any where thiers a hose, check it to make sure its tight, as an example, brake boaster needs vacume, ( if thiers a problem here you would no before check engine light is on )
