Rear end
Old May 20, 2007 | 11:31 PM
pakaalbite's Avatar
pakaalbite
Default Rear end
I have a 2005 ram 1500 with the 3.55 rear end axle ratio. Is there a different rearend i could change inorder to achieve better gas mileage?
Old May 20, 2007 | 11:45 PM
HuntinHanson's Avatar
HuntinHanson
Default RE: Rear end
you can swap your gears out for 3.92, 4.10 or 4.56, do you have any plans of increasing tire size?
Old May 21, 2007 | 12:04 AM
bltp203's Avatar
bltp203
Depends on your driving. If you do mostly highway, then I would say stay with what you have.
Old May 21, 2007 | 12:47 AM
pakaalbite's Avatar
pakaalbite
I have the OEM 20s and i dont plan on increasing the tire size. I am seventeen and i mostly just drive around town. Not much highway driving at all.
Old May 21, 2007 | 12:54 AM
HuntinHanson
i'd just leave it with 3.55's with factory tires you don't really need different gears. By the time you paid to have the gears redone especially if you have 4wd it wouldnt be worth the small amount of mpg gain
Old May 21, 2007 | 01:08 AM
pakaalbite's Avatar
pakaalbite
thanks hansonhuhc. Would the 4.56 gears help the fuel economy though?
Old May 21, 2007 | 01:13 AM
Midnightrider's Avatar
Midnightrider
4:56's really wouldnt help fuel economy if u stayed with your stock tire size because you will be reving out more. 3:55 to 4:56 is a huge jump, I run 4:56's and on the highway i noticed a huge drop in MPG, around town not so much but still alittle diffrence.
Old May 21, 2007 | 05:32 AM
djr04's Avatar
djr04
4.56's tend to increase performance and in town fuel mileage. Highway fuel mileage is generally lower, due to an rpm increase of 300-500 rpm, depending on your stock gear ratio. I don't know about you, but I drive a lot more in town that I do on the highway, so a gear swap would be beneficial for me. Make your decision based on how much performance means to you and how much you drive in town vs. highway.
Old May 21, 2007 | 03:31 PM
HuntinHanson
if you REALLY wanna gear swap to higher, the cheapest way you could do is go to a junkyard and find one that came with stock 3.92's or find someone maybe planning on swapping their stock 3.92's out for a different ratio and throw those in your truck. They would help a little, they are fairly common so they should be easy and cheaper to come by
Old May 21, 2007 | 07:21 PM
pakaalbite's Avatar
pakaalbite
very helpful information
