Door Handle removal
Old May 23, 2007 | 03:03 PM
chopperzen's Avatar
chopperzen
Default Door Handle removal
I want to paint my door handles to match the truck. I took the door panel off of the rear door to look and onlyone screw is visible holding the handle on. Where is the other one and what needs tobe done to get it off? Same with the front handles..
Old May 23, 2007 | 03:59 PM
chopperzen's Avatar
chopperzen
Default RE: Door Handle removal
Guess I asked too soon.. I figured it out!
Old May 23, 2007 | 04:05 PM
HuntinHanson's Avatar
HuntinHanson
you should post how to do it on this thread so if someone has the same question and uses the search the answer will be on this thread and they won't have to ask it again
Old May 23, 2007 | 08:48 PM
chopperzen's Avatar
chopperzen
To remove door handles: Remove door panel with Philips head. Two screws at the bottom, one at the mirror and one behind the door handle. One holds behind the door handle on the back door. Remove the Torx screw that holds the door handle to the door with a Torx 40. Pull off the panel and peel down the top corner of membrane at the door lock pins. Use a 5/16" socket to remove the nuts holding the handle on. There is a black rubber piece to remove to be able to get to the 2nd nut on the rear doors. Pull out the handles and remove the handle from the bar. That's it.
Old May 23, 2007 | 09:34 PM
Sir Hardin Thicke's Avatar
Sir Hardin Thicke
Are you using the new Duplicolor vinyl and fabric spray paint? Let us know how it works.
I saw a small segment on Truck Universe (Speed TV) where they showed a car where the owner painted the seats and door panels 2-tone. Looked great, but I'm skeptical about the durability.
Old May 24, 2007 | 01:17 PM
chopperzen's Avatar
chopperzen
As of now, I am just painting the exterior door handles. I have thought about painting the top section of the interior doors, but I'm just not sure if I want to do that. However, I have painted the lock/window control plates and the plastic around the CD player and climate controls. I can post pics of that and I will post pics of the handles when I put them on tomorrow. I have to clear coat them today..
