how much fluid
Old May 27, 2007 | 11:22 PM
marv02's Avatar
marv02
Default how much fluid
I am planning to change my Rear end fluid and Trans fluid soon.
I Have a 2006 Q-Cab 1500 with the 3.7- (6) speed manual trans with 321 open rear end.
How much fuid do they hold and I read Dodge uses ATF-4 in the trany is this right in a manual trans.
WhatWTOil should I usefor the rear diff.
I was told make sure I change the diff oil at least once a year the rear ends are not the best and I figure mite as well do the trans at the same time.
I am planning to go with AMS OIL I had good luck with them in the past, I need to order some 2 stroke mix from them anyways.
