window problem
Old May 30, 2007 | 03:21 PM
ccm182's Avatar
ccm182
Default window problem
i have a 2003 dodge ram quad cad. i am having a problem with my windows rolling up or down. the tricky part is the driver can roll all of them up or down no problem, both the right passengers only work sometimes, and the left passenger doesnt work at all. i think it is probably the switchs but i wanted to get some advice before i start tearing things apart.
Old May 30, 2007 | 03:27 PM
HuntinHanson's Avatar
HuntinHanson
Default RE: window problem
if the driver's switch never has a problem its either the switch in the other doors or a bad connection at the switch in the other doors.
Old May 30, 2007 | 03:50 PM
chopperzen's Avatar
chopperzen
My passenger controlled window does that too. Sometimes it works and sometimes it doesn't. As far as I know, the others are fine. I just blame my wife.
Old May 30, 2007 | 06:17 PM
FFMedic1479's Avatar
FFMedic1479
Bad switches or bad wiring... especially since the driver switches work fine. I think you can trouble shoot the switches by removing the controls off the driver's door (the ones you know work 100%), they unplug and come out of the door themselves... go to the other doors and plug in the switch and see if they work 100% of the time with those switches... if they do, you have bad switches, if they don't, you have bad wiring.
