2004 Ram w/infinity sound
is this possible i found this at the 12volt.com. can someone verify this?
Well the big DC has done it once again! You can no longer
put aftermarket head units into Rams built 05/04 , they
now use the bus comm. via digital signal from the head
unit to the amp to the speakers. If you want, you can bypass the amp and go directly to doors,but you will lose
your radio and install time!
natedogg
natedogg
