platium plugs,how you like yours?
Old Sep 20, 2004 | 11:36 PM
dannysdodge's Avatar
dannysdodge
Default platium plugs,how you like yours?
was thinking of installing a set of autolite platium plugs in my 03 ram 1500,since dodge recommends changing the ngk"s at 30,000 miles if you have a set in your 03 & up rams let me know how you like them thanks danny
Old Sep 21, 2004 | 10:27 AM
rcs426's Avatar
rcs426
Default RE: platium plugs,how you like yours?
won't feel abit of dif. just us stock copper truck plug from champ
Old Sep 22, 2004 | 12:26 PM
B12Teuton's Avatar
B12Teuton
I haven't changed the plugs in my Ram, but I have used BOSCH +4 Platinum plugs and they actually made a noticable improvement in both fuel economy and power in my other cars.
But they are also $6.
Old Sep 29, 2004 | 12:26 AM
AJSnRR's Avatar
AJSnRR
I was at the dealer today for a leaky rack n pinion and a 30k 28 point tune up. They had to order the parts so I will be back tomorrow. When I told the dealer rep I wanted to change the plugs to platinum myself, he told me it wouldn't help and I'd need to run premium gas after that. I have not heard of this. Is this true? If I change to platinum plugs I have to run premium. Common sense tells me if I want performance I run premium, not plugs.
2002, 1500, 4.7L
Old Sep 29, 2004 | 01:45 AM
Drew's Avatar
Drew
Ive got the single electrode bosch platnums in my little yoda (anything more than one electrode is only a gimmick BTW ) and I dont have to use premium but seeing as it is an import 4 banger there could be a few differences, but I dont see why you would need to run premium when chaging over to platnum plugs. all they offer is lower resistance and since most have a smaller surface area at the electrode it means a more intence spark for better fuel ignition.
now while 93 octane will give you more performance, if you want to stick to 87 and put in platnums, it'll give you a bit more pep that wont run you 20 cents a gallon over 87.
Old Sep 29, 2004 | 01:37 PM
purdueranger's Avatar
purdueranger
Running Premium fuel in a vehicle designed for 87 octane will not make a bit of difference unless you change timing and some tables in your pcm. The higher the octane the more timing you can run. I run Autolite platnums in my 5.2 and I run 87 octane unless i put my performance PCM in. Most people I talk to don't like using platnum plugs and just get a copper plug one heat range colder than stock. That will help prevent detonation.
