Power Outlet
maybe someone knows...
The in-dash auxiliary power outlet (under the ashtray) quit working. The fuse was blown, I replaced it, but the outlet still does not work. I tried to remove the outlet, but can't figure it out. Any ideas out there?
Thanks
Thanks
Possible short that caused the fuse to blow in the first place? You should be able to get the dash off by removing the screw in the trash bag holder clip and then pulling around the edges to release the clips; be careful though, some are tough to remove and you don't want to break those clips.
ORIGINAL: djr04
