Where is it located? EGR Position sensor performance
Old Jun 2, 2007 | 10:33 PM
Lenny's Avatar
Lenny
Default Where is it located? EGR Position sensor performance
I'm getting code P0404-EGR Position sensor performance.......where is it located so i can fix it and what does it look like? 2005 Dodge Ram Hemi
Old Jun 2, 2007 | 11:41 PM
CarGuyOhio's Avatar
CarGuyOhio
Default RE: Where is it located? EGR Position sensor performance
I just looked on mine and did not see it. EGR valves are usually on top of the intake but with the Hemi plastic cover you cannot see much. It will have a single vacuum line running to it.
You do know your 2005 Ram comes with a 7/70 power train warranty. EGR may be covered! Sorry 2006 and newer, 05 was the last year for 7/70.
Old Jun 2, 2007 | 11:47 PM
helopilot's Avatar
helopilot
As you are looking at the front of the engine it will be a silver tube encased in a black mesh shroud coming from the left rear portion of the throttle body and going along to the front left corner of the engine.
Old Jul 8, 2007 | 08:21 PM
chadmech28's Avatar
chadmech28
po406 egr position sensor highthere is a tsb 18-021-04 replace egr and flash pcm.
