passenger pwr window
Old Jun 19, 2007 | 05:08 AM
ray97's Avatar
ray97
Default passenger pwr window
Have a quick question with the passenger pwr window. On the passenger door it will work about 50% of the time, but if I use the drivers door to put it up or down I have no problem what so ever. Would this just be the passenger door switch needs to be replaced or should I start somewhere else. Just want to know before I start buying parts. Also I already looked at the switch to make sure the connection was not loose.
Old Jun 19, 2007 | 01:51 PM
John  M's Avatar
John M
Default RE: passenger pwr window
If it always works from the drivers side, that rules out any problems with the regulator. Looks like just a new passenger switch would fix it for you.
Old Jun 19, 2007 | 01:57 PM
kenihemi's Avatar
kenihemi
Make sure you didn't accidentally hit the window lock button.
Old Jun 19, 2007 | 02:27 PM
ray97's Avatar
ray97
No the lock button is off. I guess I will replace the switch.
Old Jun 19, 2007 | 05:10 PM
cpukramer's Avatar
cpukramer
I am having this same problem ... did replacing the passenger switch work?
Thanks!
Old Jun 19, 2007 | 09:16 PM
kenihemi's Avatar
kenihemi
Just a thought.
Old Jun 20, 2007 | 12:02 AM
HuntinHanson's Avatar
HuntinHanson
if your driver window switch works every time its the passenger switch, replace it and your good to go.
