Remote Keyless Entry
Old Jun 24, 2007 | 08:03 PM
carbophat's Avatar
carbophat
Default Remote Keyless Entry
So? How do you fix it? I have replaced the remotes batteries, however they didn't fix the problem? Where is the module located or if it has a fuse,where would it be? I have gone through the fuse box, but didn't see anything... Please help
Old Jun 26, 2007 | 05:27 PM
carbophat's Avatar
carbophat
Default RE: Remote Keyless Entry
Anyone?
Old Jun 26, 2007 | 05:43 PM
#Red's Avatar
#Red
You should still be covered under warranty. Just have the dealer check it out so you don’t waste your time changing stuff at your cost for nothing. Red
Old Jun 27, 2007 | 07:15 PM
Vimstar's Avatar
Vimstar
Did you resync the remote with the truck? Most of the time (at least from past experiance) when you change the battery in the keyless entry remotes or gt a new one you have to sync them to your vehicle. If thats the case there should be something in the owners manual on the resync procedure. If not then something else may be jacked up with the remote and you might need to see a dealer.
