Superchips Improves Shifting?
Old Jun 25, 2007 | 01:39 AM
CMA's Avatar
CMA
Default Superchips Improves Shifting?
I am loving my new ram, but I'd like to have better control over shifting. If Im on the highway and get on the gas, it downshifts once and then a second later when it realizes I really want to pull, it downshifts again and takes off. I think the truck would be much faster if it shifted quicker.
How much does the superchips improve shifting? Also, how much does it improve 0-60 launch? According to the 0-60 calculator http://www.060calculator.com/, a Dodge ram with 345 hp and weighing 5000lbs should be 0-60 in 6.6s. I have read around 7.9s is what the stock truck gets. So theres got to be another second hiding somewhere and I'm guessing its the shifting.
Old Jun 25, 2007 | 04:02 AM
bksram3500's Avatar
bksram3500
Default RE: Superchips Improves Shifting?
I had a Chevy with a superchip It let me program the shift points that I wanted. Not sure about the hemi
Old Jun 25, 2007 | 01:44 PM
go49ers's Avatar
go49ers
Superchips automatcally changes the shift points in Performance mode. They havent released a update to let you manually change the shift points on the newer Rams.
Old Jun 25, 2007 | 11:30 PM
mdscole's Avatar
mdscole
I have the flashpaq with the most recent update. The shifting is what makes this unit worth while. Power increases are not noticible, but the shift points sure are.
It goes to 2nd gear around residential 90* corners without flooring the throttle. It won't shift from first gear till 2300 RPM regardless of throttle position.
Mostly - it holds gears longer and downshifts more redily than the stock programming.
I like it.
Old Jun 26, 2007 | 12:13 AM
rammunition's Avatar
rammunition
We just put installed the performance setting on my dads 04 today. Shifting is the big difference we both noticed more than the power gain. His truck has a totally different feel to it than my 07 with the six speed. I still think my six speed launches faster stock if that makes any sense?
Old Jun 26, 2007 | 12:16 AM
The_Bishop's Avatar
The_Bishop
If anyone's looking for one I popped mine up on E-Bay. Listing # is 170125579889.
Old Jun 26, 2007 | 12:29 AM
FFMedic1479's Avatar
FFMedic1479
Shift points are adjustable to make the best use of the engines power. The stock 5.7 stops producing power around 5800 rpm or so, so to go any higher before it shift will show a drop in HP if you looked at it on a graph. And with the Hemi's, the tranny is already shifting at the highest pressure so you won't get a firmer shift.I think that all you are changing when you select "91 Performance" over "87 Stock" is the advancing or retarding of the timeing...
