What transmission do I have? Having Problems
Old Jul 5, 2007 | 09:29 PM
SgtCortes's Avatar
SgtCortes
Default What transmission do I have? Having Problems
Hi, pretty nice forum....
I tried using the Search feature, but did not find what I was looking for.
My question is ....what type of transmission do I have?
2002 Dodge Ram Quad 4X4
5.9L V8
69k, don't know if the tranny fluid has ever been changed, bought used at dealer. Trans Oil did not look brown.
Found these numbers on the tranny, don't know if it will help.
TK3471F1517
P52118155AL830924 kinda worn out, so I might be off
I'm thinking its the 46RE, but I'm not sure.
My tranny has 14 bolts on the pan, don't know if that is any help. Reason I'm asking is because its starting to not want to shift 2-3 or it does a "mini" shift, like 300 RPM change, then if I let go the gas it will shift.
I read in other forums that it might be the TPS or the Transmission Govenor Pressure Solenoid or the Govenor Pressure Sensor. Will do a tanny oil/filter change when I do this...
Does anybody also know if I have the Transmission with the lock up converter or not. Trying to buy parts online, but Its kinda hard if I don't know.
Old Jul 6, 2007 | 08:58 AM
SgtCortes's Avatar
SgtCortes
Default RE: What transmission do I have? Having Problems
Bump.
Old Jul 7, 2007 | 12:07 AM
SgtCortes's Avatar
SgtCortes
Well, called the dealer and gave them my VIN, I have the 46RE,
