stereo help
Old Jul 12, 2007 | 09:23 PM
justme06's Avatar
justme06
Default stereo help
ok, first, i installed all new speakers with stock headunit about a couple of week ago. after installation, i found out that the passanger side front speaker got not sound, i switch it with other speaker, stock and no sound either.
well, i though maybe the headunit is shot. so today, i got me a new headunit and after the installation, same thing happen. no sound from the passanger side speaker. is the wiring mess out? how could it be?
i didnt notice it before upgrade the speaker, should have pay attention but i didnt.
what should i do? should i rewire the wire from the headunit to the passanger side speaker? how hard to do it?
also, i got bazooka box w amp built in it, i think bta6100. how do i hook em up?? do i run a wire from battery directly? if so, dont the amp will drain the battery down?
i m on the budget so my headunit is pioneer deh1900mp, and the speakers are polk audio 650 and 690
last thing, stock stereo SUCK!!!
please do help me. thanks[/align][/align]
Old Jul 12, 2007 | 10:26 PM
chadmech28's Avatar
chadmech28
Default RE: stereo help
If you have no sound from just the one speaker, it's probally a broken wire inside the rubber that take the harness from the cab to the door. This is a pretty common problem. I would just run new wires from the deck to the speakers. There is room to accually put them threw the connector inside of that boot, if you want to make it neat. hope this helps
Old Jul 12, 2007 | 10:34 PM
casper3380's Avatar
casper3380
the system sounds good. chad is right, sounds like a broken wire. Good choice on the speakers too. As for the sub. It will either have the option of remote turn on or sensor. Run patch cables to the sub and include the turn on lead and yoiur set, will turn on when the deck does. should sound great when you are done. good luck m8
casper
Old Jul 12, 2007 | 10:45 PM
FFMedic1479's Avatar
FFMedic1479
If you are going to run new speaker wire, now is a good time (if you got the funds) to go to components and a 4 channel amp. I would hate to do it twice.
Old Jul 13, 2007 | 07:52 PM
justme06's Avatar
justme06
finally trace down my problem. the pin on the speaker connector broken off.
got it fixed and damm, i love it. i m not hardcore but the sound from the aftermarket HU and speakers do ROCK the whole truck. also hooked up the bazooka and now i got bass
thanks
Old Jul 14, 2007 | 02:19 PM
slapshot12's Avatar
slapshot12
I agree with the masses, the stock stereo was terrible. I replaced mine with a new Pioner Premier, 4 new speakers, and a 4 channel amp. I'm not into truck thumping bass and just wanted a clear, crisp sound. I definately got it with this set up. Having direct connect for Sirius instead of the FM makes a huge difference as well. My favorite new toy is having control of the iPod right on the headunit and remote.
