a/c, defrosters, temp not working
Old Jul 24, 2007 | 08:46 AM
eaker02's Avatar
eaker02
Default a/c, defrosters, temp not working
Hi all,
2004 dodge Ram 1500 quad cab.
Installed Sirius lastnight. to install had to pull the bezel to get to the radio,unplugged the cig lighter, fan control, a/c and the plug that switches from floor to defrost to vent, and the plug for a/c. redefrostetc.
Plugged everything backup after installing the 10 pin connector for Sirius.
This morning found that the a/c , the switch to swap from defrost to floor to vent is not working, the fan speed works, but not the other things..
Any ideas? I did notdisconnect the negtive cable from the battery. (forgot once I started).
if it's a fuse, where is the fuse box? doI need to unplug the battery cable and reset anything? Can't believe I've never needed to get to the fuses
Thanks
Ron
Old Jul 24, 2007 | 11:22 AM
HuntinHanson's Avatar
HuntinHanson
Default RE: a/c, defrosters, temp not working
first i'd pull that center panel back off and make sure nothing came back un hooked. When i did my stereo my A/c wires came back out of the plug on the back of the control. Must not have pushed them back in all the way even though i thought i did. If it is still connected look for any kind of damage to any wires or the back of the control, then check your fuses if your still not finding anything.
Old Jul 24, 2007 | 12:48 PM
eaker02's Avatar
eaker02
Your excatly right. It was the plug.. Pulled the bezel out at lunch and the connector was just laying there.. Swore I pushed it in all the way.. oh well.
Thanks and appreicate the tip.
Ron
Old Jul 24, 2007 | 04:54 PM
HuntinHanson
yeah thats the same exact thing i did
