ABS & Brake light - fix advice?
Old Jul 25, 2007 | 08:46 AM
Dgonthefly's Avatar
Dgonthefly
Default ABS & Brake light - fix advice?
Hey all - cool forum!
My brake light and ABS lights came on, and after reading about it, Ibought a new speed sensor for the differential. I replaced it the part, but the lights are still on.
Any thoughts on what else to try?
thanks
Old Jul 25, 2007 | 11:12 AM
HuntinHanson's Avatar
HuntinHanson
Default RE: ABS & Brake light - fix advice?
have you checked to see if your throwing any codes? i would try checking the wiring all the way back to the speed sensor. Maybe it got damaged somewhere.
Old Jul 25, 2007 | 11:17 AM
Dgonthefly's Avatar
Dgonthefly
I haven't checked for codes - I assumed if there was a code, there'd also be a check engine light. yes?
I can check the wiring. Maybe I didn't make the connection to the new sensor? Hadn't thought of that - I may try re-seating that connection.
Old Jul 25, 2007 | 11:18 AM
HuntinHanson
Most of the time you will get a CEL. But not 100% of the time. I've found a few stored codes when messing around with my superchips that i never saw a light for. I've just made it a habbit to check for codes whenever soemthing is wrong.
Old Jul 25, 2007 | 11:21 AM
Dgonthefly's Avatar
Dgonthefly
I guess it can't hurt to check.
Old Aug 6, 2007 | 10:29 AM
Dgonthefly's Avatar
Dgonthefly
Ok, I've checked all the wiring - nothing obvious, I reseated the harness to the speed sensor, checked the brake fluid levels, checked all the fuses....reset the computer.
still comes on at around 20-25 mph.
speedo works fine.
help!
