Bully dog Power pup problem fix, Hesitation, Tsb flash
This post is for all the guys with 05 and earlier hemi's that have had or are having problems with there bully dog programmer. To fix problems associated with hesitating and transmission funny business you need to have your truck flashed at the dealership with Tsb flash 18 013-05. This took care of all of my issues.My bully works great now! my truck had to have a tsb flash from the dealership to run properly with the bully. was not covered under my extended warranty. cost me 78 bucks! i think this only applies to 05 and earlier hemi's. either way i came out on top. the dealership gave me all the available tsb's and updates for my truck at the same time for 78 bucks. not bad. the tsb updates for the hemi are a good idea either way. the one needed for the programmer to function properly on certain hemi's will increase throttle response and driveability even without a performance programmer/chip.
If you are under factory warranty or extended warranty, make sure you return your truck to stock as a precaution before having it serviced. i wouldnt mention why you need the flash either. Just tell them you want the flash to help with driveability and hesitation.
And sorry Bully Dog. I blamed the programmer and it turned out to be dodge.
