Power steering fluid
Old Jul 25, 2007 | 05:05 PM
marv02's Avatar
marv02
Default Power steering fluid
Is there a special power steering fluid I need to use when topping off my power steering fluid level.
I notice the stock Fluid color isRED the aftermarket fluids are mostly clear can you mix them or is like the trans fluid a special for dodge only.
Old Jul 25, 2007 | 05:51 PM
19ramslt98's Avatar
19ramslt98
Default RE: Power steering fluid
I think it is ATF+4. Check the owners manual
Old Jul 25, 2007 | 06:55 PM
deanj287's Avatar
deanj287
its atf-4 which is also the same stuff in you trans
Old Jul 25, 2007 | 07:20 PM
marv02's Avatar
marv02
Thanks I am planning to change my trany fluid very soon with some AMSOIL or Red Line.
I will change out the P/S fluid out at the same time mite as well go to full Syntetic can't hurt.
Doing the rear diff at the same time.
