gonna be moddin
Old Jul 27, 2007 | 02:30 PM
Hellbilly1's Avatar
Hellbilly1
Default gonna be moddin
so i finally talked the wifey into my headers and well it turns out we have some extra money layin around and i talked her into a cam so hey well you cant beat that i guess i am gonna go with comp most likely would like some input on how big or what to stay away from since i have really messed with cams before thanks..
http://www.compperformancegroupstore...y_Code=EFIHEMI
if i was goin to use this would i have replace much else inside or just use whats stock
Old Jul 27, 2007 | 02:54 PM
motorider228's Avatar
motorider228
Default RE: gonna be moddin
You should go ask this question on dodge truck world in the hemi section. Those guys are more into performance than the guys over here for the most part. I'm glad to see you are not going with the 6.1 cam as there are better cams out there than that cam. To be safe with the cam swap you should replace the valve springs and pushrods as well. Also, some cams require custom tuning with an smt-6 so ask around on dodgetruckworld and find out which cams do not require tuning.
What headers are you going with?
Old Jul 27, 2007 | 02:59 PM
Hellbilly1's Avatar
Hellbilly1
mostly likely pacesetter long tubes dodgetruckworld huh ill give it a try thanks
Old Jul 27, 2007 | 03:35 PM
HammerZ71's Avatar
HammerZ71
Same route I'm taking. I've just ordered the Pacesetter LT's, I'm gonna send them to a local shop for ceramic coating (I've seen their work). Then the cams, which are going to be KRC210 +4 A special grind that produces tons of torque with almost no top end loss. As I have a QC 4x4 I'm looking more for diesel like torque than corvette like top end...
This cam also is supposed to get along well with the Superchips and not require a custom tune. Other than the normal items to go along with the cam (springs, retainers, etc.) it requires nothing extra, except a fuel controller if I want to run the Superchips "performance" tune w/o the chance of popping lean codes...
Old Jul 27, 2007 | 03:49 PM
Hellbilly1's Avatar
Hellbilly1
see i was sittin there thinkin i wanted a sleeper 4x4 then i got thinkin whats the fun in having a cam if you cant hear it and me i am partial to hearin the lope ofa big ****in cam anyways that was my thought so your just doin the springs and retainers not the pushrods??
Old Jul 27, 2007 | 10:01 PM
Hellbilly1's Avatar
Hellbilly1
anyone else have opinions
Old Jul 27, 2007 | 10:09 PM
casper3380's Avatar
casper3380
does the hemi use roller lifters and rockers? if not will need to replace the lifters atleast. How much fun is gonna be to change out the cam bearings. I havent had a chance to look. how much space is there in the back by the firewall? Good luck m8 and let us know how she does with the new cam.
