Lamp out?
Old Jul 28, 2007 | 12:38 AM
Max00racer's Avatar
Max00racer
Default RE: Lamp out?
I knew something good would come out of this haha thanks I'll be doing that tomorrow!
Old Jul 28, 2007 | 03:31 AM
abarmby's Avatar
abarmby
Do the electrical sprayclean, that has been suggested and then, when replacing the bulbs, put a little smear of hi temp silicone sealer on the bulb and it's fitting, bridging it.
When the sealers set, no vibrations will work the bulb loose and cause oxidisation on the contacts etc.
This is great for offroaders'
I've done it and have never had this for two years now.
Al.
Old Jul 29, 2007 | 02:34 AM
muscleman320's Avatar
muscleman320
well mine is doing the same thing. it came on like 4 months ago and i changed my back left bulb becasue it went out, and it still didn't come on, i ithnk the wiring is wrong somewhere. i had to have my intrument panel replace inFeb. and teh guy said some stuff could go out because it was a new wiring harness, so idk if thats it or not, but pretty sure i got ripped off on that deal too.
Old Jul 30, 2007 | 12:24 AM
ray97's Avatar
ray97
ORIGINAL: tomski74
Yep, I just had the same thing going on with my truck. I had some moisture in my tail light. I just took all the bulbs out. I sprayed the connectors with an electric contact spray and it fixed it...
Good luck!
Tomski
Same here...
