Trouble finding 20X9s?
Of all the 20's I see on fords around here Im having trouble finding standard 20X9 with a desent style and construction I wanted to stick with the same size since my gearing is already calibrated for them but if Im correct(feel free to correct me at anytime)the stock rims are 20X9 inches with a 5X5.5 bolt pattern which im not 100% on howto measure outyour bolt pattern. Anyone know of a source of rims that measure up? or do I haft to go through changing my ratio and correcting the speedo or buying spacers etc. etc. for rims that arent on the 30 other rams in town.
you bolt pattern is 5x5.5 The only way you will have to change your speedometer is if you go with bigger or smaller tires. Your new choice of rims won't be affected by your gears at all.
