06 hemi brake light and abs light on
Old Aug 6, 2007 | 04:45 PM
masonman85's Avatar
masonman85
Default 06 hemi brake light and abs light on
hey guys coming back from a little road trip and my abs light and my brake light came on my dash...it kept going on and off and beeping every damn time...neways just plugged in my superchips and 2 codes came up C1036 and C1030. any of you guys know these or have the link to all the codes since i just tried searching and cant find it anywhere. thanks
Old Aug 6, 2007 | 09:40 PM
Parts/Service's Avatar
Parts/Service
Default RE: 06 hemi brake light and abs light on
Did'nt find any info on C1030, check the wheel speed sensor on top of rear differential. It is usually the reason that you have these 2 lights on. Part number is 5032220AA. Should cost about $8.00
hope this helps.
C1036-REAR WHEEL SPEED SENSOR CIRCUIT (EBC125)
For a complete wiring diagram Refer to Section 8W[/b].
[ul][*]When Monitored:
With the ignition on and no system under voltage or over voltage condition present.[*]Set Condition:[/b]
If the measured wheel speed sensor feedback voltage is less than .277 volts, the sensor is considered open.
If the measured wheel speed sensor feedback voltage is greater than 1.277 volts, or if a sensor over current condition is detected, the sensor is considered shorted.
If a shorted or open condition is present for more than 100 msec, the DTC will set.[/ul]
Possible Causes[/b]
INTERMITTENT REAR WHEEL SPEED SENSOR DTC
(B222) REAR WHEEL SPEED SENSOR SUPPLY CIRCUIT SHORT TO GROUND
(B22) REAR WHEEL SPEED SENSOR SIGNAL CIRCUIT SHORT TO GROUND
(B222) REAR WHEEL SPEED SENSOR SUPPLY CIRCUIT OPEN
(B22) REAR WHEEL SPEED SENSOR SIGNAL CIRCUIT OPEN
(B222) REAR WHEEL SPEED SENSOR SUPPLY CIRCUIT SHORTED TO VOLTAGE
(B22) REAR WHEEL SPEED SENSOR SIGNAL CIRCUIT SHORTED TO VOLTAGE
(B222) REAR WHEEL SPEED SENSOR SUPPLY CIRCUIT SHORTED TO THE (B22) REAR WHEEL SPEED SENSOR SIGNAL CIRCUIT
TONE WHEEL
EXCESSIVE REAR WHEEL SPEED SENSOR AIR GAP
WHEEL BEARING
ANTI-LOCK BRAKE MODULE
[/b]
Diagnostic Test1. DTC IS ACTIVE [/b]
[hr]
Turn the ignition on.
With the scan tool, clear DTCs.
Turn the ignition off.
With the scan tool, select View DTCs.
Is the status Active for this DTC?Yes
[ul][*]Go To 2 [/ul]
No
[ul][*]Go To 15[/ul]
2. WHEEL SPEED SENSOR INSPECTION [/b]
[hr]
Inspect the Wheel Speed Sensor for proper mounting.
Inspect the Wheel Speed Sensor harness and connector.
Inspect the Wheel Speed Sensor for excessive debris on the sensor.
Were any problems found?Yes
[ul][*]Repair as necessary in accordance with the Service Information.[*]Perform ABS VERIFICATION TEST. (Refer to 5 - BRAKES - STANDARD PROCEDURE) [/ul]
No
[ul][*]Go To 3[/ul]
3. TONE WHEEL DAMAGED/MISSING [/b]
[hr]
Inspect the Tone Wheel in accordance with the Service Information.
NOTE: The Tone Wheel Teeth should be perfectly square, not bent or nicked.
[ul][*]Replace the Tone Wheel in accordance with the Service Information.[*]Perform ABS VERIFICATION TEST. (Refer to 5 - BRAKES - STANDARD PROCEDURE) [/ul]
No
[ul][*]Go To 4[/ul]
4. EXCESSIVE WHEEL SPEED SENSOR AIR GAP [/b]
[hr]
Measure the Wheel Speed Sensor Air Gap in accordance with the Service Information.
No
[ul][*]Go To 5[/ul]
5. WHEEL BEARING LOOSE/BINDING [/b]
[hr]
Inspect the wheel bearings for excessive run out or improper clearance in accordance with the Service Information.
No
[ul][*]Go To 6[/ul]
6. (B222) REAR WHEEL SPEED SENSOR SUPPLY CIRCUIT SHORTED TO GROUND [/b]
[hr]
Disconnect the Rear Wheel Speed Sensor harness connector.
Disconnect the Anti-lock Brake Module harness connector.
NOTE: Check connector - Clean/repair as necessary.
Measure the resistance between the (B222) Rear Wheel Speed Sensor Supply circuit and ground.
Is the resistance above 5.0 ohms?Yes
[ul][*]Go To 7 [/ul]
No
[ul][*]Repair the (B222) Rear Wheel Speed Sensor Supply circuit for a short to ground.[*]Perform ABS VERIFICATION TEST. (Refer to 5 - BRAKES - STANDARD PROCEDURE) [/ul]
7. (B22) REAR WHEEL SPEED SENSOR SIGNAL CIRCUIT SHORTED TO GROUND [/b]
[hr]
Measure the resistance between the (B22) Rear Wheel Speed Sensor Signal circuit and ground.
[ul][*]Go To 8 [/ul]
No
[ul][*]Repair the (B22) Rear Wheel Speed Sensor Signal circuit for a short to ground.[*]Perform ABS VERIFICATION TEST. (Refer to 5 - BRAKES - STANDARD PROCEDURE) [/ul]
8. (B222) REAR WHEEL SPEED SENSOR SUPPLY CIRCUIT OPEN [/b]
[hr]
Measure the resistance of the (B222) Rear Wheel Speed Sensor Supply circuit.
Is the resistance below 5 ohms?Yes
[ul][*]Go To 9 [/ul]
No
[ul][*]Repair the open (B222) Rear Wheel Speed Sensor Supply circuit.[*]Perform ABS VERIFICATION TEST. (Refer to 5 - BRAKES - STANDARD PROCEDURE) [/ul]
9. (B22) REAR WHEEL SPEED SENSOR SIGNAL CIRCUIT OPEN [/b]
[hr]
Measure the resistance of the (B22) Rear Wheel Speed Sensor Signal circuit.
[ul][*]Go To 10 [/ul]
No
[ul][*]Repair the open (B22) Rear Wheel Speed Sensor Signal circuit.[*]Perform ABS VERIFICATION TEST. (Refer to 5 - BRAKES - STANDARD PROCEDURE) [/ul]
10. (B222) REAR WHEEL SPEED SENSOR SUPPLY CIRCUIT SHORTED TO VOLTAGE [/b]
[hr]
Measure the voltage of the (B222) Rear Wheel Speed Sensor Supply circuit.
Is there any voltage present?Yes
[ul][*]Repair (B222) Rear Wheel Speed Sensor Supply circuit for a short to voltage.[*]Perform ABS VERIFICATION TEST. (Refer to 5 - BRAKES - STANDARD PROCEDURE) [/ul]
No
[ul][*]Go To 11[/ul]
11. (B22) REAR WHEEL SPEED SENSOR SIGNAL CIRCUIT SHORTED TO VOLTAGE [/b]
[hr]
Measure the voltage of the (B22) Rear Wheel Speed Sensor Signal circuit.
[ul][*]Repair the (B22) Rear Wheel Speed Sensor Signal circuit for a short to voltage.[*]Perform ABS VERIFICATION TEST. (Refer to 5 - BRAKES - STANDARD PROCEDURE) [/ul]
No
[ul][*]Go To 12[/ul]
12. (B222) REAR WHEEL SPEED SENSOR SUPPLY CIRCUIT SHORTED TO THE (B22) REAR WHEEL SPEED SENSOR SIGNAL CIRCUIT [/b]
[hr]
Measure the resistance between the (B222) Rear Wheel Speed Sensor Supply circuit and the (B22) Rear Wheel Speed Sensor Signal circuit at the Anti-lock Brake Module harness connector.
Is the resistance below 5.0 ohms?Yes
[ul][*]Repair (B222) Rear Wheel Speed Sensor Supply circuit for a short to the (B22) Rear Wheel Speed Sensor Signal circuit.[*]Perform ABS VERIFICATION TEST. (Refer to 5 - BRAKES - STANDARD PROCEDURE) [/ul]
No
[ul][*]Go To 13[/ul]
13. REAR WHEEL SPEED SENSOR [/b]
[hr]
Connect the Rear Wheel Speed Sensor harness connector.
Measure the resistance between the (B222) Rear Wheel Speed Sensor Supply circuit and (B22) Rear Wheel Speed Sensor Signal circuit at the Anti-lock Brake Module harness connector.
NOTE: The resistance should be approximately 1600–2300 ohms at 76° F (24.5° C).
Is the resistance within the noted range?Yes
[ul][*]Go to 14 [/ul]
No
[ul][*]Replace the Rear Wheel Speed Sensor in accordance with the Service Information.[*]Perform ABS VERIFICATION TEST.(Refer to 5 - BRAKES - STANDARD PROCEDURE) [/ul]
14. ANTI-LOCK BRAKE MODULE [/b]
[hr]
Inspect the related wiring harness. Look for any chafed, pierced, pinched, or partially broken wires.
Inspect the related wire harness connectors. Look for broken, bent, pushed out, or corroded terminals.
Refer to any Technical Service Bulletins that may apply.
[ul][*]Repair as necessary in accordance with the Service Information.[*]Perform ABS VERIFICATION TEST.(Refer to 5 - BRAKES - STANDARD PROCEDURE) [/ul]
No
[ul][*]Replace the Anti-lock Brake Module in accordance with the Service Information.[*]Perform ABS VERIFICATION TEST.(Refer to 5 - BRAKES - STANDARD PROCEDURE) [/ul]
15. WIRING HARNESS INSPECTION [/b]
[hr]
NOTE: Towing the vehicle with ignition ON may set this DTC.
No
[ul][*]Test Complete.[/ul]
Old Aug 6, 2007 | 09:44 PM
masonman85's Avatar
masonman85
thanks i'll take a look at it in the morning...this sensor is on the outside of the diff ?
Old Aug 6, 2007 | 09:57 PM
Parts/Service
Yes on top,ouside of diff.
REMOVAL
1 - WHEEL SPEED SENSOR
2 - MOUNTING STUD
3 - AXLE HOUSING
[ol][*]Raise the vehicle on a hoist.[*]Remove the brake line mounting nut and remove the brake line from the sensor stud.[*]Remove the mounting stud (2) from the sensor and shield (REAR WHEEL SPEED SENSOR).[*]Remove the sensor (1) and shield from the differential housing (3).[*]Disconnect the sensor wire harness and remove the sensor (1).[/ol]
Old Aug 7, 2007 | 01:10 AM
muscleman320's Avatar
muscleman320
same thing happened to me, fill up your brake fluid .. it'll go off
Old Aug 7, 2007 | 01:14 AM
muscleman320
i forgot to say .. does it go on and off and ding numerous times in a row.. mostly when you go over a rough road surface .. i drove like that for 2 months and had no idea what it was and it drove me insane, finally a guy at the auto store told me to fill up my brake fluid .. sure enough it was that easy no dings since .. i'd try that beore checkin all those sensors and stuff
