fan clutch
Old Aug 18, 2007 | 06:28 PM
myns's Avatar
myns
Default fan clutch
my 02 truck is showing the code for the fan clutch relay but my truck doesnt even have a fan clutch its electric fan can anyone help thanks ?
Old Aug 21, 2007 | 05:21 PM
myns's Avatar
myns
Default RE: fan clutch
has no one had this problem
Old Aug 21, 2007 | 05:25 PM
nastyram's Avatar
nastyram
are you talking about the fan for the a/c
Old Aug 22, 2007 | 10:44 AM
ryema's Avatar
ryema
I had the same problem with my 02 last fall. I took it to the Dodge Dealership and it cost me around three hundred to fix the fan.
Old Aug 22, 2007 | 11:37 AM
OldMoparMan's Avatar
OldMoparMan
ORIGINAL: myns
You have an electric fan with a relay for your A/C fan, that's over the condenser, and you have a Fan Clutch, that's manual, mounted between the waterpump and the fan blades. It works thermostatically with a bi-metal spring/fluid drive system. No relay what so ever.......
Seeing that it's the "Fan Relay", it would be for the electric fan for the a/c. (fan on the left-driver's side)
The dealership gets $242 for a fan clutch. NAPA gets $59 for the same thing.....[:@]
Not sure about relay prices. CHeck your fan for obstructions or even if it works (wired manually) before just buying a relay. A bad fan motor will cause relay failure and produce the same code, in some instances. Simple troubleshooting will tell you the problem.
