unlock doors when put in park
Old Aug 22, 2007 | 04:55 PM
gymfreek69's Avatar
gymfreek69
Default unlock doors when put in park
isnt there a way to make the doors unlock when you put the truck back into lock automatically? i think i tried the procedure in the manual and had no luck. i found the adberwhater about hitting the keyless once or twice or whatnot and was just wondering if there was anything out there on my issue as well. thanks
Old Aug 22, 2007 | 06:32 PM
Pirata's Avatar
Pirata
From: 2nd star to the right, then straight on until morning
Default RE: unlock doors when put in park
I don't know about the unlocking in park but I do know you can't turn off the honk function on the 07 without the dealer doing it regardless of what the manual say. If there is a procedure for unlocking the doors in park it might also be one the dealer may haveto do.
Old Aug 22, 2007 | 07:14 PM
a4twenty's Avatar
a4twenty
ORIGINAL: Pirata
god that has been bugging me, i have tried like 20 times ...................
thanx
Parts/Service's Avatar
Parts/Service
A dealer can use a StarScan to enable it for you. Take it back to where you bought it, they should do it for free.
Old Aug 22, 2007 | 08:00 PM
Sir Hardin Thicke's Avatar
Sir Hardin Thicke
the doors will automatically unlock when you put it in park, but ONLY of the ignition is turned off.
Old Aug 23, 2007 | 08:07 AM
Sir Hardin Thicke
ORIGINAL: Sir Hardin Thicke
I stand corrected. The door will only unlock when the truck is put in Park, the ignition is turned off, and you open the driver's door. That is unless the dealer can do something with the scan tool.
