2004 1500 ram w hemi.
Old Oct 23, 2004 | 10:34 PM
jbsram's Avatar
jbsram
Default 2004 1500 ram w hemi.
Has anyone put true dual exhausts (took out y pipe) run duals all the way back? and a K&N filter kit ? I did low end torque is pretty crappy and gas mileage sucks (11.5 ) anyone else had experience with this?
Old Oct 23, 2004 | 10:42 PM
moparturd's Avatar
moparturd
Default RE: 2004 1500 ram w hemi.
I have read elsewhere that other have had the very same results. Did you go large on the pipe size, like 2.5 or bigger?
Old Oct 23, 2004 | 11:00 PM
B][GT's Avatar
B][GT
Everyone has asked this, and everyone thats done it has experienced the same thing.. sucky that you wasted that kinda money on the exhuast.
Old Oct 24, 2004 | 12:43 AM
moparturd's Avatar
moparturd
It would probably work half way decent if they wouldn't go way be on the pipe size. If you would go with a 2 inch you'd probably be OK.
Old Oct 24, 2004 | 01:54 PM
jbsram's Avatar
jbsram
Yes they used 2.5" pipe all the way. they put in a x type muffler in front of dual mufflers after initial install it brought back low end torque pretty well, but then I put K&N on and low end was gone again and it was loud through mufflers again. Whats the best thing to do ?get rid of K&N and dually"s any suggestions?
I will probably have to put a y pipe back in and go with a single in ,dual out muffler and tailpipes ?
Old Oct 24, 2004 | 03:01 PM
moparturd's Avatar
moparturd
That seems to be what everyoneis doing to bring it back. The other option is to just leave it and get a PCM programmer for your truck. With that, your improvements may be OK.
Old Oct 27, 2004 | 09:37 PM
whodunnit's Avatar
whodunnit
I have an 04 Hemi. Dualed out with a 2 Chanber Flow master (2 in and 2 out) with 2 inch pipe. I haven't noticed any loss in power or torque and the gas mile is running 14.7 in the city and 16.5 on the highway if I can drive for a long distance.
Just my .02
Old Oct 27, 2004 | 10:06 PM
moparturd's Avatar
moparturd
Cool. Where did they neck the pipe down at? How far downstream from the converter?
Old Oct 28, 2004 | 02:30 AM
whodunnit's Avatar
whodunnit
After reading your response I got to thinking and had to go look and it seems I told yall wrong to begin with. What I have is 1, 2 chamber flow master with 1 inlet and 2 outlet and 2 in pipe to the back. what they did was cut right in from of the first (big muffler under the cab) and that is where they placed the flow master. If I had it to do all over again I think I would go with a 3 chamber because it gets a little loud when I'm pulling my boat. Maybe I'm just getting old.
Old Oct 28, 2004 | 02:48 AM
kerry's Avatar
kerry
yes, the same deal,on my 04 quad hemi
