Old Aug 6, 2015, 01:56 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Specifications & General Maintenance
Print Wikipost
home link garage door opener
Old Sep 17, 2007 | 05:30 PM
tnh's Avatar
tnh
Default home link garage door opener
i recently totaled an 02 1500 quad, got the insurance money and bought an 07 1500 quad 5.7.
before the adjuster took the 02, i got my nerf bars and overhead console. my question is:
1. will the nerf bars fit the 07?
2. will the homelink work on the 07? if not, can you get a home link for the 07 thru anybody, dodge or ???
i tried installing the homelink to the 07 and the truck would not start and turned the check engine light on.
i figured it has something to do with the fuse capability of the circuit.
longstory short, is there any way to put the homelink on the 2007?
Old Sep 17, 2007 | 06:22 PM
KRZY.BMET's Avatar
KRZY.BMET
Peaceful Browser
Default RE: home link garage door opener
As far as the Homelink goes, I found this for you.
http://www.opendoorsandmore.com/
The nerf bars are a different story. The only way you are going to tell is to see if the bolt pattern will match up under the truck. I would bet no though. If it doesn't fit, try to sell your set for the '02 to offset the cost of a new set for the '07.
Old Sep 18, 2007 | 07:11 AM
gchildre's Avatar
gchildre
If the homelink console doesn't fit, sell it on ebay to fund a new one. I bought a homelink console there, they don't last very long. I puchased a 2002 homelink console on ebay without thesunglass holder and just switched the module over to my console - keeping the sunglass holder that came original in mine. The console module is a self contained unit and there were no additional wires needed.
Old Sep 18, 2007 | 07:39 AM
motorhead426's Avatar
motorhead426
ORIGINAL: tnh
I never could getthe homelink to work in my 2005. But I will tell you one thing about your "no-start" situation. When the dealer replaced my headliner, there was soemthing wrong with the harness on it (it has a factory moonroof), the truck wouldn't start when you either plugged in the new harness, or left the harness unplugged all together. The connector is in the Drivers A-pillar. Chrysler likes to control EVERYTHING through the PCM.
Also, I was told that the 2006+ models don't use fuses. They use the "CAN-BUS" system, so its like relays or something. A guy at work blew out a circuit with his trailer lights and it caused a bunch of other things to not work. When the dealer went to fix it, they said that there is a few bad modules out there, so it took a few tries to get it right. So good luck adding anything electrical to your 2007.
Old Sep 18, 2007 | 09:52 AM
Foiled's Avatar
Foiled
The BUS on the 02 and 07 are different. You will need the console for an 06-08 to work on yours.
Sorry.
