Rancho Leveling Kit
Old Sep 20, 2007 | 09:07 PM
MAB_CTD_4X4's Avatar
MAB_CTD_4X4
Default RE: Rancho Leveling Kit
It will make the noise by just backing out the driveway or some times just turning the wheel. It goes back to the shop on Oct. 1 and I talked to Rancho yesterday and the tech said it sound like the spring was not seated correct
Old Oct 1, 2007 | 08:25 PM
MAB_CTD_4X4
Put the truck back in the shop today and they found that it was the track bar that was making the noise. Seems that the nut on the passenger side that holds the track bar has a tab made on to it because you can't get a wrench on it and they had the tab turned the wrong way and when the truck would load and unload the spring this tab would hit and pop causing a sound to resonate through the track bar. So all is well now....
Old Oct 1, 2007 | 09:04 PM
88xj's Avatar
88xj
Member
ORIGINAL: nuckingfuts22
If thats the case you will need to have your struts replaced. They are over taxed and will need to be replaced to a stronger strut to fix the issue. The quick lift would have been a much better option for you because its a taller strut and it also takes care of the strut clicking like it is.
umm doesnt the 2500 have a solid axle and not the coilover suspension the 1500 have.
