Dome Light Removal
Old Oct 8, 2007 | 06:34 AM
starneml's Avatar
starneml
Default Dome Light Removal
I searched and didn't see this question asked.
How do I remove the Dome light in the center of the headliner in a 2002 Ram 1500?
(I want to remove it so that I can install an antenna in the center of the roof of the cab)
I can't seem to find the magic trick to get it out.
The 2nd Gen RAM was easy, but this one is being stubborn.
Thanks
Mark
Old Oct 9, 2007 | 07:18 AM
gchildre's Avatar
gchildre
Default RE: Dome Light Removal
I removed mine once to install a wireless headphone antenna in the headliner, I'm pretty sure you just use a small flat blade screwdriver on the driver side of the lens and carefully pop the lens down and it hinges out. I don't think the dome light is attached to the roof, just the headliner.
Good luck
Old Oct 9, 2007 | 07:58 AM
tdmopar59's Avatar
tdmopar59
another thing to try is using a regular head screwdriver to pop out the lense and there might be a couple of torx head screws holding it in... thats what holds the overhead display up...
