Rear End Shutter???
Old Oct 20, 2007 | 09:47 PM
Grizz's Avatar
Grizz
Default Rear End Shutter???
Does anyone elseexperience this slight shutter???Here's the scnario, when I stop at a traffic light or stop sign then accelerate normally while turning 90 degrees to the left or right I can feel a slight shutter or shake coming from what feels like the the rear end. It almost feels like driving over a set of old worn down smooth rumble strips. This is the only time it seems to happen and as far as I can tell, everything else is fine.
I have no idea when this started to happen as I purchased this truck used, it has no warranty and has done this since purchase. It's a 2003 Dodge Ram 2500 HD 5.7 hemi long box quad cab.
Old Oct 20, 2007 | 10:17 PM
John  M's Avatar
John M
Default RE: Rear End Shutter???
Mine does it too, and has since I bought it maybe 6 months ago. I'll find out soon if it's "normal"; it's going in for a trans & diff flush and fill. Then I'll find out if I'm experiencing any of the all-to-common problems with the stock LSD. 2500's don't have the problem diff so you should be fine.
Old Oct 20, 2007 | 10:54 PM
Grizz's Avatar
Grizz
I'm glad to hear I am not the only one experiencing this shutter!! I would however like to figure out what is causing it, has anyone else experienced this issue??? Does anyone else know whatmay becausing it???
Old Oct 21, 2007 | 12:09 AM
marv02's Avatar
marv02
My old 1999 Ford Expendition use to do that I had the trany fliud FLUSHED out that cured the shuttering form a stop light.
Old Oct 21, 2007 | 03:50 AM
Grizz's Avatar
Grizz
ORIGINAL: marv02
Thanks for the reply, I'll definately try that. In the mean time, I was looking throught the TBS's on this site and came accross one:
Bulleitn # 0300304
Sequence # 10008043
Date- 06/05/04
All itsays is"Launch Shudder *tt"
Do you have to be a dealer to look it up? If so could someone let me know what this TSB is, I wonder if it applies towhat I am experiencing in the above post.
Old Oct 21, 2007 | 05:51 AM
moparmutt's Avatar
moparmutt
My truck did that when I first got it. I have a LSD. Changed the fluid in the diffs and added LSD additive to the rear. Then it went away. Also checked to make sure that the clips were there. Mine checked out good, there wasn't even much on the magnet.
Change the fluid, you will notice a big difference, I did. It worth a shot anyways.
Sorry I forgot you said it was a 2500. They're not the same as a 1500 LSD.
Old Oct 21, 2007 | 06:27 PM
BLACKTRX4's Avatar
BLACKTRX4
Mine does that but I know it's from the posi rear.
Old Oct 21, 2007 | 08:38 PM
cmoschip's Avatar
cmoschip
With the 2500 you could still have an LSD. AAM axles (you have the 10.5 inch) has a clutch type and a helical gear type - I think Dodge selects the helical gear type to resell but I'm not sure.
Old Oct 21, 2007 | 10:56 PM
pacblueram's Avatar
pacblueram
ORIGINAL: Grizz
Mine did that too. Dealer could not tell me what it was...They told me to keep an eye on it. Then, of course, the warranty ran out, and the rear end actually locked up. Of course, I was screwed when it came to getting it fixed since the warranty was up. I had the fluid changed in the rear when I got the truck at 59k...and again at 75k. locked up at 90k. However, I was unaware of having to put the synthetic in the fluid too...But I assumed it was getting done by the guys changing the fluid if it needed done. Anyway, have the rear checked out. Get it fixed before it goes, especially after the warranty, becuase Dodge does not care about you after that point.
Old Oct 22, 2007 | 12:26 AM
Hessmonster's Avatar
Hessmonster
My 2500 does this as well. I've heard a lot of 1500 truck have the "clip" problem in he rear end. I'm scared to take mine to the dealer. Do you think the 7/70 powertrain warrenty will cover this?
