2500 leveling kits
Old Oct 23, 2007 | 08:54 PM
Traillblazer's Avatar
Traillblazer
Default 2500 leveling kits
I have been digging for a while trying to come up with some information about a leveling kit for the 3/4 tons. I found a lot of info for the 1500's, but not for the 2500's. I am new to Dodges, and I have found a wide variety of leveling kits for the 2500's ranging from 80 bucks on up to almost 300. Does anyone have any advice on these? I found bolt in spacers on ebay, and urethane spacers from companys such as pro comp i believe. I don't want something that is going to be unreliable or when i get it found out i bought something hazardous to my truck. Thanks for the info in advace.
2004 Dodge 2500 crew cab short bed
Old Oct 23, 2007 | 11:02 PM
tdmopar59's Avatar
tdmopar59
Default RE: 2500 leveling kits
i have a top guns customz and it seems to work great... i also heard good things about daystar and pro comp...
Old Oct 24, 2007 | 10:14 PM
Traillblazer
did you keep your stock shocks or did you get extended shocks? did you need to compress the coils?
Old Oct 24, 2007 | 11:10 PM
2004hemi4x4's Avatar
2004hemi4x4
yea he has stock shocks
yes that coil is in there very good , you have to compress it a good bit
Old Oct 24, 2007 | 11:30 PM
tdmopar59's Avatar
tdmopar59
yea 2004hemi4x4 is right (he helped with the install) i had to use a coil spring compressor, compress them as much as possible.... bolt in the new coil spacer than jam the coil in there and take off the spring compressor.... and yea im runnin stock shocks for now...
