Help with diagnostic codes
Old Nov 2, 2007 | 09:42 PM
PyRoHAvoC's Avatar
PyRoHAvoC
Default Help with diagnostic codes
P0442
P0456
Truck overheating... Stranded in some little crap town...
Already swapped the thermostat.
Old Nov 2, 2007 | 09:43 PM
Parts/Service's Avatar
Parts/Service
Default RE: Help with diagnostic codes
What year and motor?
Old Nov 2, 2007 | 09:48 PM
PyRoHAvoC's Avatar
PyRoHAvoC
woops..
2003 4.7l
Old Nov 2, 2007 | 09:49 PM
hemiyellow's Avatar
hemiyellow
DC Insider
P0442 - EVAP System Medium Leak
P0456 - EVAP System Small Leak
tighten the gas cap enough? usually what these codes are caused by, also check the EVAP hoses by the canister....
how many miles, and all the good stuff....more info would be great so we can try and help ya out more
Old Nov 2, 2007 | 09:52 PM
Parts/Service
Don't think that these codes are related to overheating. Check all rubber hoses under hood and under body for an evap leak to cure these codes.....
Old Nov 2, 2007 | 09:53 PM
PyRoHAvoC's Avatar
PyRoHAvoC
So we have a 2003 4.7l Dodge ram...
Was cruising down the road.. all good.. then made one pit stop and back one the road again.. car started to overheat. Thought it was thermostat, so changed it and ran the truck for 15 minutes no more bubbles in stream. Car is parked a/c on and it started to overheat again. What else could we check to find out what it is ?
Radiator cap off,
turned off engine because the gauge was pegged hot...
Bubbles in the reservoir tank sometimes, then it stops then it starts bubbling again.. Along with fluctuations in the reservoir tank... as in it rises then it falls
When more water gets added, it gets angry.
Here is what i have posted at another forum..
Old Nov 2, 2007 | 10:02 PM
buzzard217's Avatar
buzzard217
Look at the water pump weep hole, see if its been leaking. Also if you are anywhere near an Auto Zone or something you can buy a exhaust gas tester. Its a little plastic container that has a chemical in it that changes color if there is the pres of exhaust gas. If you dont find any water leaking somewhere and the chemical changes color I would bet money that you have a blown head gasket.
Old Nov 2, 2007 | 10:03 PM
PyRoHAvoC's Avatar
PyRoHAvoC
65k miles
