mtx audio
Old Nov 4, 2007 | 10:53 PM
kx250frider617's Avatar
kx250frider617
Default mtx audio
Does anyone here have the mtx thunderform w/ 2 10" 4500's box that goes under the rear seat. I know there are loaded and amplified versions of this box. Does it sound good. All i want is my truck to bump.
Old Nov 4, 2007 | 11:05 PM
tdmopar59's Avatar
tdmopar59
Default RE: mtx audio
i was lookin at these set ups too... i think fully loaded with an amp and everything is close to $650thought which is quite a lot in my opinion.... i would imagine it sounds pretty good though....
Old Nov 4, 2007 | 11:20 PM
kx250frider617
yea your pretty much paying for the box though. I know the subs and the amp are name brand but the cheapest.
Old Nov 4, 2007 | 11:31 PM
tdmopar59's Avatar
tdmopar59
i personally think i might just try to build my own box or something... i cant justify spending so much on a box....
Old Nov 5, 2007 | 12:05 AM
kx250frider617
I was thinking that too. maybe take out the front center seat and build a box there were the cosole part could bolt to the box. Or even somehow raise the passenger seat and have a box under there. Just a few ideas.
Old Nov 5, 2007 | 12:21 AM
tdmopar59's Avatar
tdmopar59
well a lot of the boxes on the market go under the rear seat... i was thinking that i would do something along these lines... i figure around sprig time i will put some money on the side for this kind of project.... i'll do some measurements and see what i can do.... maybe i'll even design it on CAD for ya'll... only if i find a good design though... i want to build one ported because it allows the sub to hit much better and i want to put two 10's back there... i think i might go with power acoustiks or kickers... keep me posted on the kind of set up you are going with....
Old Nov 5, 2007 | 01:17 AM
JD1500's Avatar
JD1500
Look at Pioneer's new flat subs. (they have a flat top) they are very easy to mount under the seat yourself, and can also be placesd very easily under the front seats. They are desinged for open air as well, so sound good just stuck under the seats, with a little mdf around the edges.
Stair step boxes are also very easily built. and sound good. You just loose your center rear seat.
Old Nov 5, 2007 | 10:08 AM
The Peddler's Avatar
The Peddler
Don't spend your money on this stuff,you can build the box yourself! I made my on box just like what you would buy, and I made it for about $20. I got my two 10's and my amp off of ebay,put all of it together for about $90. BTW it sounds great!!!
Box made myself---$20
450 watt 10's------$40
650 watt amp------$30
Old Nov 5, 2007 | 10:10 AM
tdmopar59's Avatar
tdmopar59
peddler you got any pics?
Old Nov 5, 2007 | 10:13 AM
The Peddler
I am at work right now,but I will get you some pics as soon as I can.
