30k Sevice.
Old Nov 5, 2007 | 01:13 AM
JD1500's Avatar
JD1500
Default 30k Sevice.
Just changed oil, air filter, and rear end fluid.
Checked all others. Anything else i should be looking at doing?
Old Nov 5, 2007 | 08:02 AM
Wishbone's Avatar
Wishbone
Default RE: 30k Sevice.
Yes, spark plugs and coolant are due as well.
Old Nov 5, 2007 | 09:27 AM
tdmopar59's Avatar
tdmopar59
spark plugs, and a pcv valve....
Old Nov 5, 2007 | 12:07 PM
United1's Avatar
United1
If you tow it might not be a bad idea to do the trans and also if you have 4wd to do the front diff.
Old Nov 5, 2007 | 12:28 PM
tdmopar59's Avatar
tdmopar59
ORIGINAL: United1
yea this is true... change th filters and flush the trans...
Old Nov 5, 2007 | 12:36 PM
MikeHTally's Avatar
MikeHTally
Ditto all that. You may only need to change the sump filter in the trans. I think the cooler filter is every other 30K. PCV valve may only need cleaning. Take the TB off and see if it needs a bath. I took mine off last Saturday. Wasn't very bad, but I cleaned it anyway.
Old Nov 5, 2007 | 12:41 PM
turbot_bird's Avatar
turbot_bird
yes, on these dodge trannys, it seems to be important to take car of the fluid and filters lol. I would also do the plugs, they have got to be geting worn, I pulled mine at 23,400 and they where bad.
