Rear Axel
you can get gasket material form any auto parts store and cut your own, but the easiest way to do it is rtv sealant, gasket material in a tube. just thick bead.works great, just let it set up before you put the fluid in the diff. there is a diy post on it in that section.
If you're interested in a gasket, here's a FelPro version I've used:
FEL-PRO Part # RDS55073Rear Axle; (12-bolt holes); Chrysler 9.25" R.G.
I get mine from Rockauto.com. I prefer the gasket, to RTV since there's no scraping on take-off and no waiting for the RTV to setup before adding the diff oil. Directions say wait 2 hours. Of course the new Permatex "Right-Stuff" fixes the wait problem since assembly can be immediate. However, take-off is still harder than with a gasket.
