Old Aug 5, 2015, 01:35 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior
Print Wikipost
Installed a backup camera
Old Nov 10, 2007 | 11:27 PM
BartL's Avatar
BartL
Default RE: Installed a backup camera
nypanama42, yes, the monitor folds down and retracts into the receiver when I turn the backup camera's signal off or the receiver off. This Jensen DVD-receiver was one of the least expensive, 1 DIN, models with this feature. I wanted a retractable monitor (or a visor-mounted monitor) to provide an uncluttered look on my instrument panel. The monitors that mount on top of the dashboard work okay but either restrict visibility or seem to clutter up the panel.
No, I can put my camera's image on the monitor at any time by depressing the manual bypass switch to one side to feed a 12 v. input
(from the nearby cigarette lighter) to the "signal" wire. That tells the DVD to route the camera's image to the monitor. If I depress the manual bypass switch to the other side (making the connection to the backup light switch), the camera's image will be routed to the monitor only when the truck is put into reverse. However, I haven't made that second connection yet. I found out that I could have installed a single pole, double throw relay of some sort to do the same thing. However, installing a manual switch seemed less complicated to me - since I'm not an electronics expert by any means.
LarryL
Old Nov 11, 2007 | 01:06 AM
tdmopar59's Avatar
tdmopar59
Lookin good!!!
Old Nov 11, 2007 | 03:26 AM
TraptuR's Avatar
TraptuR
pretty sweet dude!
Old Nov 11, 2007 | 10:00 AM
Lama's Avatar
Lama
Thanks for sharing this. I’ve been considering a DVD Player but the ceiling units I’ve seen for the Dodge looks big and bulky. The DVD setup you have looks perfect. Is it also possible to have another receiver mounted from the cab ceiling for rear passengers?
Old Nov 11, 2007 | 08:00 PM
BartL's Avatar
BartL
Lama, many of these DVD-receivers with monitors have provision to send the video feed to a second monitor. You can purchase a ceiling monitor for the rear of your truck or headrest monitors that fit into the rear of the front seat headrests. If you play a DVD of a movie, the movie will be shown on all monitors. If the DVD-receiver unit is correctly wired with an input from the parking brake's switch, only the rear seat monitors will show the images from the video while the vehicle is moving. The images will be locked out from the front seat's monitor.
LarryL
