Cleaned out my throttle body today...
Old Nov 13, 2007 | 09:29 AM
tdmopar59's Avatar
tdmopar59
Default RE: Cleaned out my throttle body today...
its an engine.... nothing in an engine is clean... ever! theres always build up of dirt.... as far as cleaning it.. its much easier cleaning a little off every once in a while then scrubbing it when its real bad!.. theres a reason for routine maintanance!
Old Nov 13, 2007 | 09:49 AM
minnesotamopar's Avatar
minnesotamopar
I guess what I was getting at was even with my old TBI engines and living on a gravel road in crop land, I didn't have a level of grime build up to alter performance, and is there something specific to these engines that is causing build up?
Is it aftermarket parts allowing more silt and dust into the intake? For instance aftermarket air filters or cold air setups?
I'm by no means new to engines and realize they're inherently dirty, but to affect performance in such a way as some have explained is out of hand.
--Matt
Old Nov 13, 2007 | 09:53 AM
tdmopar59's Avatar
tdmopar59
well aftermarket intakes do tend to let a little bit more through but not much... just think about it thought theres thousands of little explosions going on in your engine every minute.. that gets messy!
Old Nov 13, 2007 | 10:36 AM
spud11's Avatar
spud11
Grease and grime has a remarkable ablity to worm its way into the strangest places, on the vehicle and themechanic.
Old Nov 13, 2007 | 03:54 PM
dg2003's Avatar
dg2003
I'd be interested in a DIY on the throttle body cleaning and PCV valve change for my '03. Thanks.
Old Nov 13, 2007 | 05:21 PM
Dire Wolf's Avatar
Dire Wolf
ORIGINAL: dg2003
I looked at this before I decided to do it. When I took mine off it looked fairly clean until I turned it around, it was caked with black dirt.
http://home.comcast.net/%7Esteveusmc/PCVandTB.doc
I wouldnt bother cleaning the PCV Valve, just replace it. I got mine at Napa for $27 or so, you can also get them at the Dodge Dealer for a few dollars more.
Old Nov 13, 2007 | 09:06 PM
Brother Rob's Avatar
Brother Rob
Retired Moderator
ORIGINAL: Dire Wolf
Noticed a big improvement on throttle response and a smoother idle. I will give it a few weeks to see if my MPG improves from 10.1.
Wow, that's not very good MPG with all your mods. Are you a speed freak or was that throttle body packed with ****?!!
Old Nov 13, 2007 | 10:41 PM
JimmyDiablo's Avatar
JimmyDiablo
ORIGINAL: tdmopar59
yea they all have a pcv valve... this weekend i might be doing some of that... anyone want a DIY for cleaning your throttle body and replacing your PCV valve for the hemi??
Can you please post one Greg, I woul dlove to do that also
Old Nov 14, 2007 | 05:44 PM
Dire Wolf's Avatar
Dire Wolf
ORIGINAL: Brother Rob
ORIGINAL: Dire Wolf
Not a speed freak but I do get on it alot.
Old Nov 14, 2007 | 05:46 PM
Dire Wolf's Avatar
Dire Wolf
ORIGINAL: jimmydaleo
ORIGINAL: tdmopar59
I got this from the Hemitruckclub.com
