rear end
Old Nov 15, 2007 | 03:41 AM
HammerZ71's Avatar
HammerZ71
Default RE: rear end
Go with the 4.56's for either towing or larger than stock tires. All this crap about higher rpm's & lower gas mileage is exaggerated. My RPM's at a given speed are up about 400 from when I had stock 3.92's. Mileage ranges from about 1mpg better in town to about 1 mpg worse on the interstate.
For any truck with over about 30k miles on it, go with the master install kit.
Old Nov 15, 2007 | 08:06 AM
ce2flaco's Avatar
ce2flaco
ORIGINAL: supermotojoe
I think if you had two trucks side by side one with 17" like stock and 20" you would see the smaller tires offer more get up and go and probably better mpg. The biggers tires must pay a price on mpg. Anyone out there with 17"? What kind of milage are you getting. theroetically a set of 4:66 gear sets would = having 17" tires (my math my be off a bit). Again this is all based on the factory not changing gear sets when they put 20" tires on, I may be wrong. Either way it's gonna go faster when i'm done with it.
Typically the 17" wheel is running a tire with a taller sidewall increasing it's overall diameter to a similar number as the 20's that run a fairly low profile tire. The wheel size itself means nothing. The overall diameter of the tire is the key.
http://www.rocky-road.com/calculator.html
This is a link to a gear/tire/ calculator.
4.10's with 35" tires will put you very close to stock rpm's while 4.56's will give you a bit more performance than a stock set up.
Old Nov 15, 2007 | 08:55 AM
supermotojoe's Avatar
supermotojoe
thanks to all and for sure ce2flaco. The calculator is just the tool. I think that's going to convince me to change gears 1st. Great site! I will keep you all posted as I go.
