Will double-din dvd fit a 2006? Need info ASAP!
Old Nov 16, 2007 | 05:45 PM
XtremeXP's Avatar
XtremeXP
Default Will double-din dvd fit a 2006? Need info ASAP!
I'm looking at a Pioneer AVH-P6800DVD double din dvd player. Does anyone know if this will fit my 2006? It has the factory radio/cd player in it now. No navigation.
Old Nov 16, 2007 | 05:56 PM
XtremeXP's Avatar
XtremeXP
Default RE: Will double-din dvd fit a 2006? Need info ASAP!
Reading up a little I'm thinking it should fit but I would have to buy the radio bezel for the navigation unit. Am I right?
Old Nov 16, 2007 | 06:30 PM
jojo's Avatar
jojo
Your correct, with the naviation bazel it will work factory look, but if your handy with a dremel you can also make it fit in your stock setup.
Old Nov 16, 2007 | 08:50 PM
JD1500's Avatar
JD1500
I did a buddies with the stock. we figured if we messed it up, we could just get the nav bezel to replace it. Worked good, fit great doing it ourselves. It's easy to try things when you have an insurance policy (ie factory part to cover it)
Old Nov 16, 2007 | 10:09 PM
XtremeXP's Avatar
XtremeXP
Thanks for the info!
Old Nov 16, 2007 | 11:09 PM
NYPANAMA42's Avatar
NYPANAMA42
Let us see how it looks when its done.
Old Nov 16, 2007 | 11:14 PM
Piston's Avatar
Piston
If you want, try it yourself, if not, you can get the nav dash peice for around $100 on ebay or a dealer, then you can order up the dash kit from a metra dealer part #99-6510
Jason
